Introducing our two new Mighty Minis, the FT Mighty Mini F-22 and the FT Mighty Mini Vector!
The Vector is a mashup of different designs, and a lot of the inspiration came from the SU-47. Peter built his Vector out of FT Water Resistant Foam Board.
The Vector features a removable nose and can be upgraded with a rudder tab to help with yaw control and high alpha. It runs off of Power Pack F, with 2300 kv 2204 motors. The Vector is pretty speedy and flies with great maneuverability.
The FT Mighty Mini F-22 also flies faster and maneuvers better than its larger counterpart. It can run on 2204 or 1806 motors, but if you use 1806 motors, be sure to use something larger than a 2S battery to ensure it has enough power.
Josh and Peter fitted their Minis with boxing gloves to try to knock Alex’s quad out of the sky…but had little success. :)
Peter recently served as a pit technician for the World Drone Prix in Dubai and flew his fixed wing jet around the FPV racing course.
The FT Mighty Mini F-22 and FT Vector speed build kits include FT Water Resistant Foam Board and are now available in the FT Store!
This website http://www.skillsyouneed.com/num/percent-change.html gives you the formula as well as a "calculator" to determine percentage increase/decrease. I have found it very helpful in changing size of airplane plans.
pls
