The FT Mighty Mini F-22 has all of the excitement of the full-scale F-22 packed into a miniature version!
The Mini F-22 speed build kit is laser cut into our new Water-Resistant Foam Board! Learn more about the Water-Resistant foam kit HERE!
This plane is a little more versatile indoors or in tight surroundings than its original counterpart. It's a blast to fly and just as agile as the F-22!
The Mini F-22 can be powered by a 2300 kv 2204 motor or a 2280 kv 1806 motor.
GET THE SPEED BUILD KIT HERE!
FT MIGHTY MINI F-22 SPECS
- Weight without battery: 4.8 oz (134 g)
- Center of Gravity: 14 inches (355 mm) from the nose
- Control Surface Throws: 25° deflection (elevons) Expo 30%
- Wingspan: 20 inches (508 mm)
- Recommended motor: 2300 kv 2204 or 2280 kv 1806 motor
- Recommended prop: 6 x 4.5 prop
- Recommended ESC: 12 amp minimum
- Recommended battery: 800 mAH 3s minimum
- Recommended servos: 5 gram servos
FT MIGHTY MINI F-22 PLANS
- FT Mighty Mini F-22 Raptor [FULL]
- FT Mighty Mini F-22 Raptor [TILED]
- FT Mighty Mini F-22 Raptor [All in one]
STORE LINKS
- FT Mighty Mini F-22 Raptor Laser Cut (Speed Build) Kit
- Electronics Pack (Power Pack F or Power Pack A)
- Transmitters
- Receivers
New to the R/C hobby?
Here’s some resources to help get you up to speed!
Beginner Series: WATCH HERE!
Electronics Setup: WATCH HERE!
First Flight Quick Tips: WATCH HERE!
Got glue?? Get some here!
I'm a new member of the hobby and your two new planes look good. whilst your on the subject of this kind of plane, can you please consider creating another EDF? From Australia, The Ancient Ace.
-Josh Bixler, 2016
i have designed a wing for your mini f-22 raptor. That is its a foam fighter similar to your mini f-22 raptor ,same body, same things except the wing . I had a design for a fighter and i designed it , to make it real and easy i just swapped my wing design to your raptor frame or body.Please try out this design.
https://drive.google.com/open?id=0B_WuCi9yUh_3R2Zlb21GS2JqRkU
yours faithfully
Devadershan
Jon
