One would assume that because these planes are 200% larger that the build would be 200% harder. Great news. This isn't the case!
Josh and David show how they brought these monster planes to life!
The monsters build exactly like the normal swappables but the name of the game here is structural integrity.
On the normal FT Spitfire the power pod provides a great amount of strength for the fuselage.
To compensate for the absent power pod on the monster, David built a similar style box to keep the fuselage from buckling in on itself.
The motor mount was built from lauan plywood and LOTS of glue. Hot glue to be exact. CA glue didn't quite hold up to the vibrations from the motor and you can see the results below.
Here are the big fat control horns. The patterns for these are available in the Monster FT Cruiser Plans.
The belly is lined with a thin plywood to prevent the rubber bands that hold the wings from digging into the foam.
The wings for the Monster FT Cruiser couldn't be removed like David's Spitfire, so Josh decided to use a technique called shear webbing. Usually this is done with wood but here we use foam.
He also used a joining spar with a screw to connect the wing to the fuselage.
More simply, the long spar coming out of the wing is inserted into a tab in the fuselage. Kind of like big flying Legos!
Here is a bottom shot of Josh's motor mount.
One amazingly easy and fun addition to any huge plane are bomb bays! All it takes is a box, an extra servo, and a hinge line.
To keep the tail rudder strong Josh reinforced the mounts with a thin sheet of plywood.
For more detailed explanations of these techniques check out the episode!
The number one rule for monster planes is DON'T BE INTIMIDATED! The build time is more lengthy but the flying is surprisingly more docile and smooth.
Also take these techniques and apply them to any plane that you wish. We would love to see your success with any of our plans or your personal ones!
We thank you again for letting us do projects like this and hope that we have given you the inspiration to try this yourself!
PLANS
Monster FT Cruiser Electronics
- Motor: 2826-04 x2
- Prop: 13x6.5 APC
- ESC: Favorite 80A x2
- Servos: BMS620MG x4
- Battery: 3S10,000mAH
Monster FT Spitfire Electronics
- Motor: C5065 270 Kv
- Prop: 20X10 Xoar
- ESC: Turnigy dlux 80A HV
- Servos: HK47111DMG x4
- Battery: 6S5000mAH
What plane would you like to see made into a monster? Let us know! Chat it up in the forums!
You asked: Monster Viggen with TWO ducted fans in it.
A 200% Version of the Kraken would also be nice.
This would be A great build simple flat side fuselage
What ever you make is worth watching ..got the Viggen and also need a source for the 2" or 4" blue foam for the first Viggen.
This would be A great build simple flat side fuselage , the BD-5 PUSHER , a James bond natural.
Viggen and craken. Woo hoo u guys rock.
David, can you share your print settings please. Many thanks.
Super size anything! Its all entertaining.
You could maybe even "drop" a 50% plane from a 200% plane :)
then maybe do some air-combat with the 50% planes against the "motherships" of the opponent? :D
Happy 400th guys!
everyone loves it
it has the background - Pete Bowes
and your Spitfire almost resembles it
what do you think?
http://sparkyflight.wordpress.com/2014/04/04/flight-test-monster-spitfire-plans-on-30-x-20-sheets/
If the Flitetest guys would prefer me not to host them, let me know and I'll take them down.
I have beeeeeeen racking my brains to print these plans!!
thanks again gowan,i owe you a pic of my plane when I do it!
if you could do that for all of ft aircraft,i think they would like that.I know I would,as im lazy and don't want to tape 221 half blank papers together like I did with a kraken (182 pgs)
So what would the limits be for foam board construction? Would it be possible to make a small single seater airplane that one could actually pilot?
i want to make my own aircraft (BIG).
its also my first time flying.
looks great
Keep up the good work guys.
Turnigy G160 Brushless Outrunner 290kv (160 Glow) from hobby king.
Thank you for any help :)
haha GREAT episode guys!
In all you do, do it to the glory of God
KEEP FLYING! KEEP SHOOTING! AND KEEP BEING AWESOME!
-jonathan hanson from alaska
Thanks and keep up the great designs.
However, I would highly recommend going to your local Kinkos/FedEx or other large format printing place (sign companies usually have this, too) and get them to print out the plans on a single sheet. It shouldn't cost more than $20-$30. If you print the plans on an inkjet printer, it'll cost you at least that in paper and ink.
Please!!!
i cant download the plans
thanks
mens i want i know
I wonder if there is a FT- SPITFIRE plant has her giant TILED ?
Monster FT Spitfire but the tiled ..... pls send for my email carlos123cesar@gmail.com
